RTV Back on NYC Locals(with issues) | SatelliteGuys.US
Juan
33,041
10,285
Moscow Russia
Channel 42 (WSAH) but I cant seem to record the channel (eastern arc). I remember someone else had similar issues but I don't remember what the fix was. The timer fires but I get a "blank screen" when i attempt to watch the channel.
It should work the same way you would record a satellite channel. Does the recording have a time duration when you go to My Recordings? You might also check your timer and the EPG if the information is accurate. Please let me know.
This is a satellite channel (channel 8119)..I see the channel and show ok on "live" tv but i can't record it. the recording just has a blank screen.I can't skip backwards either. I cant pause live TV. This just happens on this one channel. I see a duration time of the length of the"recorded" program..This is a satellite channel part of the NYC locals..It was a "home shopping" that recently switched to RTV. The program guide information is also correct
Thanks for posting the channel info. I thought the only way I could get RTV on my dishnet sub was to add the ota tuner. I get it via 83W but now I can record the channel thanks
Nobody has any ideas? DIRT?? If not I guess no one can say I'm dumber than DIRT LOL If no one responds these bad puns will continue. Yes this is a threat
Dishnetwork website change
Both remotes control tuner 1 in dual mode.
