RTN Program Guide | SatelliteGuys.US
RTN Program Guide
smata67
118
What's the best way to know what's on? Is my only option going to TitanTv and entering each set of call letters? Seems like alot of work. Maybe there is some other service where one's selections can be saved and shared with all, is this possible with TitanTv or some other service?
It doenst take that long to enter in all the call signs on titan, about 5 minutes and your done. Titantv seems to work well, I have been using it since I first got into fta.
agreed on Titan TV
You can enter whatever you want. Some have just the G10 stuff. I have a few more (AMC4, Montana PBS, my locals, etc)
I have my local stations, and every station from all 4 birds I am on that are available. For the few that are not on Titan - I check with FTAlist (White Springs), and GNF Movies I have to go to their website.
You can save your channel settings on TitanTV. That way each time you go to the site you are presented with your own customized channel list. As mentioned above you can assign what channel number you want for each station so your online list can coordinate with your FTA receiver. I like the search feature where you can search for a particular program on only the channels you receive.
Its WNGS :)
But it works fine here. I just said "antenna only" and then added the stations
Iceberg said:
Its WNGS :)
OK I cant seem to find "antenna only" to select. Is that in the customize or favorites section? It only seems to want to pull in my local area channels. :confused:
I assume you have set up a username and password for TitanTV. If not, you'll need to do that to save your settings.
Go to your programming grid (showing your local channels), and click on the "customize" button. You'll find it at the upper right margin of the program listings.
Once you click on it you'll see spaces to add a new channel and what channel assignment you want to give it in your programming grid. So for instance you could say KWCE and 20 if it comes in on your receiver as channel 20. It really doesn't matter what channel number you assign to it. The channel number is entirely for your convenience.
Each time you add a channel it will show up in your list. When you have entered all of the channels you want, click on "save". Now when you go to your grid you should have a very useful program guide.
TitanTV 97W
Does TitanTV mainly work with just American stations in English, or does it work with things like all the other channels on Intelsat 5 @ 97W?
Thanks.....
It works very well thanks. The only problem I've noticed is KEGS brings up spanish info only. Not sure why that is.
Thanks all. Took just a few minutes. Hawaii 5-0 @ 2pm, 7pm, and 10pm. Who could ask for more?
Titan TV is the bomb when it comes to this stuff. I'm working on my list now. Adding all the affiliate stations.
Next, would LOVE to add ABC News Now, Russia Today, CCTV, but that's another day of research for me. So far, Titan Tv is pretty good for me.
GNF TV Schedule
Are some E* sats Ku (linear)?
