RTN and Tuff Signal | SatelliteGuys.US
RTN and Tuff Signal
Keystone7
507
74
North Indiana
My signal is pretty low and sometimes not there. Wanted to know if it's a problem at my end or its the sat? Thanks!
You have a good dish and a good LNBF. You should be getting a good, reliable signal with only ocasional glitches. I use a 1m dish with an Invacom LNBF. Only very seldom I don't get a good recording.
Peaking your dish may give you a better signal. Don't forget to check the LNBF skew (even on a motorized setup) to be sure it is not a few degrees off. Also try moving the LNBF closer/further from the dish for optimal reception. You may just be slightly off alignment.
I was having a problem with the channels taking forever to sinc, thought maybe my old channel list was problem (using brand new lnb), deleted the transponder, done a blind scan and it never picked up the transponder at all that the 2 channels are on. entered it manually, scanned the TP and all it good again, but still takes a while for them to sink, but once they do, great signal strength...
I've been having the same problem in mid-mo for the last couple months with RTV & Tuff tv , a little tweaking use to help , but this last week I've lost almost all signal . Plan on changing lnb and checking coaxal cable this weekend , figured the problem was all mine , since no on else was having problems ????
I have been having a lot of the same loss of signal but I'm further north and east using a 75E S/C dish (26 X 36") so it has to be dead on.I tweeked it yesterday and it seems better and we've been having nothing but rain for over a week.
Openbox S10 For Sale On Fleabay?
HELP ON HOW TO TRACK MBC FREQUENCIES
