Rotator Advice | SatelliteGuys.US
Rotator Advice
coloradosat
7
Northern Colorado
First, thanks to all of you for your great knowledge and willingness to help-out the rest of us.
It seems that I can't go wrong with purchasing a CM-9521A. However, I just can't get over the necessity of the rotator wire.
Can anyone recommend a system that uses the coax? Is it true that there is a trade-off in accuracy whenever the hard wired system is not used?
Thanks!
I didn't know there was such a thing as a rotator that works with coaxial.. do you have a link for one?
Combining Two Antennas
TV Skips season is here!!!
