RGB or Component | SatelliteGuys.US
RGB or Component
twodutys
95
Brighton, Co
Can anyone tell me for sure if Voom is running RGB or Component. The installer told me it was RGB so I set the Mits to RGB. My tint control doesn't work and my green is pushing. Voom has no Idea what I'm talking about. And the Mits manual says to go component instead of RGB because the timing may be off on the RGB. I guess there is no standard for RGB.
STB's Component outputs are Y/Pr/Pb. See here.
update on tree trimmings !!!!
Voom Receiver Dimensions?
