"Restricted" Songs | SatelliteGuys.US
"Restricted" Songs
MarketMan753
4
Finally got my XM Complete set up and everything seemed to be working. Even was able to record a couple of songs initially, but now no song is recording and the the screen is showing each song played/recording then being added to the "restricted" counter and not written to final disk space. Would anyone know what this means? Is there a work-around? There doesn't appear to be any documentation support in the TT Recast manual. Thnx
PROBLEM RESOLVED -- Just discovered that turning on the Grab or Kill lists without putting anything in the folders will stall ANY recording. (This should be documented in the manual.)
In any case, everything works as promoted. (BTW, noticable difference in record quality between using the XM Direct device and Online Direct.)
I will make sure that Derek makes note of your comment so that it makes it into the docs and the FAQ.
David
Time Trax
ANy Visualizations in TimeTrax Recast 1.24
Sirius radio complete not working
