Restoring orignal color of B&W photos | SatelliteGuys.US
Not open for further replies.
al_madhi
81
Riyadh - Saudi Arabia
Hi guys wondering is it possible to restore original colors of old B&W photos , by the same procedure they did for coloring old B&W movies .
Any thoughts you would have be greatlt appreciated .
korsjs said:
i am sure it is possible. have you looked at adobe photo shop or any other photo editors?
To - korsjs thanks for reply
does adobe photoshop programm recognize the true orignal colors of the objects in the old B&W photos whey they photographed ., Or according to the person who run the programm color the objects on his choice .
cheers .
I use PSP 9 (Paint Shop Pro)
I'm not aware of any program that can reliably colorize a picture because light blues and reds are similar in luminance. So it is best guess for clothing/fabric. Flesh tones are easier.
Dark tones of blues, reds, purples, and blacks are a best guess too.
It is hit and miss. It can take a lot of time depending on the detail you want. YOu basically paint a color over the B&W area while preserving the image.
PSP is free for 30-60 days to try. I think adobe has a trial period too.
I did a quick google search with the following terms...
colorizing black white photo*
IT came back with try-before-u-buy software and methods to colorize photos manually.
Sorry to be so general... I don't do enough to be a big help. I do more restoration and crack removal. A lot of it is almost art, because you have to imagine what would look good and fill in the blank area.
Here is one I did taking a person out of a photo.I animated it to show the process. I renamed it remove.gif. (turn on animations if they are off in your browser)
Honda Ridgeline - Any opinions?
Best Buy Price Match Bullsh!t:
