Hi all, I'm just about ready to start putting up my 10 foot C-band dish and would really like to try and find a replacement polar bushing.
I believe the hub assembly was made by Omega Systems and the plastic part I need is 7 5/8 inches long with a ID of 1 7/8 inch and an OD of 2 1/16. The plastic is about 1 1/16 thick and I think it might be made of polyethylene.
I checked standard PVC and it is between 1 1/2 inch and 2 inch PVC. It is also thinner then SCH 40.
The plastic bushing may have been a cut sheet that was rolled up using heat. I have been looking around town for polyethylene sheet but so far no luck.
Thinking of maybe trying to cut a section out of a plastic 5 gallon pail and roll it using a heat gun.
Anybody have any ideas that might work better?
Thanks, DC
Thanks, DC
