T Tom H. Active SatelliteGuys Member Original poster Dec 13, 2005 19 0 Hobe Sound, FL Aug 17, 2011 #1 When I select to disable Shared View, the receiver looses audio thru the analog (L/R) inputs only. But everything works fine when Shared View is enabled. Any suggestions?
KAB SatelliteGuys Master Pub Member / Supporter Lifetime Supporter Sep 20, 2005 22,336 6,344 Fishers, IN Aug 17, 2011 #2 Sounds like you are using TV2 audio out, not TV1's.
Z ZachS@DISH SatelliteGuys Pro Jun 14, 2011 1,726 159 Denver, Colorado Aug 17, 2011 #3 KAB said: Sounds like you are using TV2 audio out, not TV1's. Click to expand... I would double check the audio connections, that sounds like the problem to me as well.
T Tom H. Active SatelliteGuys Member Original poster Dec 13, 2005 19 0 Hobe Sound, FL Aug 17, 2011 #4 DOH!! I wont say how many times I crawled behind the thing to check connections! Thanks KAB and Zach
