remote uhf power enhancement | SatelliteGuys.US
Red_dog
60
I have read somewhere but I can not find the thread.
What is the code (button to push) increase the uhf remote distance on the 6/0 remote.
I don't know if there is such a thing or not, however, I do remember reading something (here) a few months back, that someone thought the UHF PRO remotes had 2 channels - A & B, and one of them was weaker than the other.
On the 6.3, you change from A to B from inside the battery compartment.
Otherwise... You can relocate your UHF antenna from the back of the receiver, to elsewhere, using a coaxal cable. Even to another room.
Go to the area where your remote just starts not to work and press Browse, Theme, and Record.
Then go a little further away and repeat process. :)
With a 622 and the TV2 6.3 UHF Pro remote, you can extend the range by switching from the A range to the B range. That will only allow operating TV2 with a 6.2 or 6.3 UHF Pro though. Get the receiver to the System Info screen, remove the battery cover and change the switch from A to B and hit Record on the remote. TV2 on the System info screen should now say "B range" instead of "A range
Putting my dish card in another receiver?
VIP622 remote question....
