Remote Repair | SatelliteGuys.US
Remote Repair
Former member 134676
1,167
24
I'm having issues with a receiver kind of doing a system restore without me doing it. Ever few days it wipes all my setting out (besides quick tune and parental settings) like it just came out of the box and being new hooked up. The agent said they were sending my information to a department (can't recall name). She said it would take 24/48 hours and should be fixed. I asked if its remotely done and she said yes. Is this true?
Sent from my iPhone 5 using SatelliteGuys
Not to disagree with claude, as i have no idea how this could be happening or what exactly is happening. But..
In the past issues relating to how the box performed, were usually solved by replacing the box..
I respectfully have my doubts with remotely fixing this.
Sent from my PG06100 using Tapatalk 2
I guess if it keeps it up ill just call again. I just thought they'd replace it and fix it on their end before putting back in the warehouse to be used again.
Used DECA kits?
Installer refused to remove his dirty boots
