remote programming | SatelliteGuys.US
remote programming
zakary95
21
i have a directv hd dvr and an regular hd box in the same room but on operates a tv in another room the remotes change both boxes at the same time is there a way to change the ir codes for each remote i use ir learning remotes for my systems
Check the menu for the remote setup. You should find the answer there.
HR-20 Audio Problems
Bellsouth/DirecTV services?
