Remote Plus | SatelliteGuys.US
Remote Plus
scdown
38
Denver
What is the purpose of Remote Plus? Is it just to say that recordings, by default, go to the chosen tuner unless already recording? If disabled, does that effectively mean I can only record one program at a time? Or is this a null feature until later software releases?
I apologize in advance for what seems a n00b question, but hey, I am one, and I can't find many references to Remote Plus, here or on Google- any input would be greatly appreciated!
Since record plus only works when in dual mode (which the 922 won't do) it's doesn't really do anything on the 922. What is is for is to pick which "TV" will be primarily use for recordings unless it's already recording. When off what is done is timers made on TV1 record on 1 and timers made on TV2 record on 2.
Not having the MLB Network probably isn't hurting Dish much
Acceptable Signal Strenght
