T This1 SatelliteGuys Pro Original poster May 27, 2009 261 1 Florida Nov 20, 2009 #1 Just bought a RF remote Rc644 and trying to program it for my Samsung DLP tried all of the codes and none of them work. Is there anymore codes or trick to get it programed
rad Supporting Founder Supporting Founder Lifetime Supporter Cutting Edge Sep 7, 2003 11,648 6,130 Dripping Springs, TX Nov 20, 2009 #2 Did you plug your TV's model number into DIRECTV - Remote Control Code Search and try any of the codes it came up with? You can also look in the manual for the remote and use the procedure for scanning all the codes in the remote until you find one that works.
T This1 SatelliteGuys Pro Original poster May 27, 2009 261 1 Florida Nov 20, 2009 #3 no this didn't work I am a little confused my IR R64 remote worked while programed. the RF doesn't when I program it
T This1 SatelliteGuys Pro Original poster May 27, 2009 261 1 Florida Nov 20, 2009 #4 got to work I was using av1 for tv just moved to tv and it worked.
F FED-UP-INSTALLER SatelliteGuys Pro Apr 15, 2008 355 0 Nov 21, 2009 #5 pretty sure rf feature only works on the dtv receiver not your tv
