? regarding upgrade from 508 to 625 | SatelliteGuys.US
bnewt
1,488
550
Shepherdsville, Ky
Since I have an older tv, here is my setup using the 508 & antenna for locals:
508 via coax feeds into a channel 3/4 combiner, along with the coax feed from the antenna. Those signals are combined & fed via a single coax into a splitter that feeds 3 tvs. Any of the tvs can watch the satellite feed or any of the local channels. My tvs are all set to receive the satellite programming on channel 4. My question is if I switch to the 625, I will want to use tv2 to feed all of the tvs since it produces the stereo signal, will I still be able to use my present channel combiner since it is a 3/4. I know that I will have to change the receiving channel on the tv to 21-69. I will want to use tv1 as the primary tuner for recording & tv2 tuner for viewing with all tvs.
Locals On Dish 105 In Hampton Roads Va
EPG Data Errors - A Growing Problem???
