Recording with Azbox | SatelliteGuys.US
putney
854
6
St Louis, missouri
Here's a dumb question; When I do a 'on the fly' recording, how do I stop it?
I haven't done much recording with this box, but my remote seems to get crippled while recording. A hard reboot is my fix. I would like to record in this manner. What's the trick?
while its recording press the record button. A pop up will show up with the info
time the program started and the "end" time which is 2 hours from the start time with an option to add or remove time
There is an option to press "stop" and it will stop the recording. The other 2 options are extend and cancel
Press the record button, or press Menu and select Record.
Pretty much the same for stopping, just select stop - but it seems to take a while to recover from stopping, it's not instant.
I waited two minute after selecting stop. Nothing happened.
I'll try hitting record and looking for the pop up.
Thanks!
Well I recorded the Met yesterday. It made 4gig .tmp files. I knew about the 4gig thing, but I had to put it on my mac and change it to .ts
Great picture, choppy playback on my mac (dual 2.4ghz)
Cannot Get Wifi to work
Edit .dat files w/ my PC?
