Recording from DirecTV DVR R10 | SatelliteGuys.US
kmac59
Is there anyway to record programs that were recorded on my Tivo? It has an outputs for video and audio. Can a computer with DVD-R be connected so as to burn a DVD or a separate DVD recorder?
Thanks,
Keith
Does it have the ethernet connection like the ReplayTV does so you can D/L programs to your HDD so that you can then burn them?
The DTivo R-10 doesn't have a way as of yet to move programs from the DVR to a hard drive unless you have a TV card in your PC and stream it that way.
This includes any reasonable hacks that you can do on other DirecTivos.
The R10 requires a hardware level modification, to enable hacks.
And you can use any type of digital bridge: PC Card (as Neutron said), or you could use a DV-Camcorder, or a third-party external capture device.
Or record to a DVD (via DVD-Burner), and then rip the DVD...
ect....
Triple LNB and Multiswitch Question
Dvr R10
