Record Plus... | SatelliteGuys.US
Record Plus...
riski
48
...just a quick question regarding record plus. I can enable TV2 and force all recordings to go to TV2 but I cannot get the opposite to happen...enable TV1 and force all recordings to go to TV1. The change appears on the record plus menu but when I record/DVR a program, it still goes to TV2. Any idea of what I am doing wrong?? Thanks in advance.
When record plus is set to TV2 it will work fine if you use the TV1 remote. But when you use the TV2 remote, all recordings will go to TV2 no matter what. To get recordings to go to TV1, when using the TV2 remote, you'll have to switch the record plus setting to TV1. But then you'll have the same problem when using the TV1 remote.
A solution is to temporarily set record plus to TV1 if using the TV2 remote to set a timer that you want to record on TV1.
Another solution is to leave record plus set to TV2 and just use the TV1 remote to set your timers.
Why the requirement of separate dish feeds
Recordings don't work after recording.
