Reception and time of day | SatelliteGuys.US
TiminMb
700
Winnipeg, Manitoba
I find that my morning to afternoon reception is so much poorer than the evenings and nighttime, despite clear skies.
Is this truly a phenomenon relating to signal strength, or should I suspect some other factor at work, like the sun shining on my dish or mount and distorting it?
ood question! I was about to ask this myself. I would also like to add a 2nd part to this question - Does the season affect the signal too? For example, is the signal strength usually better one time of year than the other? like winter vs summer?
Heat related LNBF frequency drifting is most likely the culprit. Try swapping out the LNBF if possible to trouble shoot. Try adjusting the LNBF LO frequency up or down in 1 MHz steps while observing a specific troublesome transponder frequency for quality level improvements.
A few years ago, I made several long distance trips to my mother's home to remedy a similar problem that caused the satellite signal to breakup between 4-7pm on very hot days. Servicing without a spectrum analyzer, I replaced the LNB on the first trip, The next trip the coax was replaced in case moisture had been wicked into an unseen damaged area. Third trip was with an analyzer, but unfortuantely for me (not my mother), the receiver was working when I arrived ..... AARRGGHH .... could only detect a slight RF pulse that I tracked to a nearby electrical transformer. Forth trip caught the picture breaking up and an incredibly strong RF signal from the power transformer. The power company crew found that the transformer was failing and the high demand during hot weather aggrivated the malfunction. The transformer was replaced and the satellite reception was not lost again until the BUD was disassembled some years later.....
Then there is the recent story about a self-install customer of an Adventistsat system... it would work fine if mounted temporarily on the ground, but poorly on the roof. After much trouble shooting with our telephone technicians, a local technician was scheduled and found that a local microwave tower's transmission was causing the interference. The neighbor's home was sheilding the dish when it was on the ground.
Many unrelated devices around our installs can be the cause of what originally be thought to be satellite equipment failure.
With my p* dishs and c/ku band lnbs (on BUDs) I dont notice a difference. I do notice a slight difference on my winegard 76 cm, better reception when cooler.
Without blocking the front of the LNBF from signal path to the dish, you might consider rigging up a shroud (like an umbrella) to block much of the direct rays of midday sun from heating the LNBF. Or experiment with a small bleach jug, which is painted white in color---giving the advantage of both heat dissipation due to the white color, and keeping direct sunlight off the case of the LNBF. Venting by cutting a hole on the bottom is recommended to reduce heat buildup as well as avoiding trapped water.
Didn't realize it was the heat that was doing this signal loss to my invacom lnb. I just figured that it had to do with the weather since I'm gone most of the day to work, I never really notice it that much during mid day. I just though clouds came more around the time the sun came up and went down, and dissappated during the night... Around here, that seems to be a usual weather trend - the sun comes up, earth and atmosphere heat up, all is nice and sunny... Sun goes down, big difference starts happening in cool and warm air meeting, storms brew and rain comes.
I know that amc3 drops out every Saturday at 11:00, right be fore Red Green comes on and then ROCKETS back up as soon as the ending credits roll =)
How do you keep the tube from bending?
coolsat
