Yeah it seems to just apply to the H20, and with the updates on this box having slowed down a timeframe hasnt been given that im aware of on when if even a fix is coming.Me too on the H20, much much slower then beofre. All the updates on the HR20 have not had this effect.
If you are talking about the H20 yes ive noticed it too, there is a whole big thread on another forum that talks about this. Not sure if a fix is in the works since i didnt read that much of it. Its annoying, but the only time i use my h20 is late night in my bedroom just for noise when im trying to sleep.
DBS forum. not sure what the thread name was, should be able to run a search and find it easily, if i get a chance ill look and postCan you mention what other forum? The slowness is really annoying, maybe there is something that can be done to speed it up.
I have a H20-600 and it updated early this morning around 330 or so.
Yeah the new server is up and you can get on if your ISP has the new addressThanks, I figured it was over there. They are having server issues, I wasn't able to get on earlier.
hmm, i didnt even have to reset, i just went and turned the tv on and noticed it right away. Maybe its a staggered rollout of the update?Mine was pretty slow later last night. I will reset etc... and see if that helps.
Could not a big thread on DBS about this, tell me what section if you get a chance
Thanks for the help.
Limited time offer
