tjdjr said:Hello.
If I buy a receiver from e-bay or something like that, how do I go about activating it? Is it as simple as taking the card out of my old receiver and putting it in the new one or does Directv have to activate it?
Don't take what I said a 100% maybe somebody else could chime in and verify what I am saiding. The old card is usually tie to the old account and D* requires you to puchase a new card(for 20$). If the receiver is one that the box had never been open and the card inside had never been activated then yes you could use that card when you activate it.tjdjr said:So the old card wouldn't work with the new receiver?
I would say you have been lucky in getting a CSR to activate your old card on a new (to you) receiver. Yes I have seen it posted a few times but I would guess about 80-90% are refused and sold a new card. This seems to be Directv's official stance.billbillw said:Both of you are wrong. It is very easy to take your old card (as long as its a P5) and have D* activate it with a used/refurbished box. I've done it 3 times already. You just call D* after installing everything and ask to marry the old card to the new receiver.
You will need the old Card #, the new receiver ID#, and the new receiver serial # (taken from the menu, not the back of the box)
If they say they can't, insist and ask to speak to a resolution specialist. They will connect you to the right department. It may take a little longer, but it is possible.
dishrich said:If the card in the old receiver is active at the time, there should be no problem moving it to a new (or new to you) receiver - done it several times for customers with NO problems. On the contrary, a couple of times the past month or two, when I have been replacing old receivers with new ones w/new cards, the CSR has even asked me "are you reusing the old card in the new unit", which actually even surprised me.
It is true that if you have an old card & it has been inactive for a month or two, then it becomes no good & can't be reused even on the same receiver it came out of.
Tom Cahill said:I have installed and activated several used receivers that we took out from the 72.5 upgrade projects.Some have been out as long as 6 months and still no problem.This first mistake most people make is to start asking the CSR questions.Just tell them you either are adding a receiver or are swapping out a receiver,what ever the case is.They will then ask for the card #,receiver ID and serial.It is that easy I have never been told I could not reuse an access card EVER.
sateck01 said:guys.
as long as the p4 card is registered in the subs name, and was never de-activated. any sbca registered tech can marry it to any ird. you as a sub who is too cheap to pay for a service call , may have a problem. now if the card was shut down, forget it. im a catholic and even christ couldnt raise it from the dead, its done.
new card is 20 and if you are a good sub .....free
sorry to be blunt, but are you all cheapsters or what??
all you do by installing on your own is void the install warranty.and in most cases the eq warranty
....bob
DirecTV*Tier2Tech said:btw, there are no such thing as p5 cards, to clarify you can use the card out of your current rec, you cannot use the card that came with the replacement, also before you consider buying from ebay you may want to ask dtv about erp options. there is no need to ask for a resolution specialist, any tier 1 or 2 agent can do this.
Limited time offer
