I heard if I try to deactivate a receiver that I own Directv will demand I return it, is this true?
Can you explain what you mean?Rec. must be really old if they do own it. Some people think if they order from Solid Signal etc. they own them. You can pay several hundred dollars and it's still a lease.
If you got the Directv receiver from Solid Signal, it's a lease, you don't own it.Can you explain what you mean?
If I buy a Dish Network receiver from Solid Signal, I own it and never have to return it. How is it different with Directv?
Is there anyway of buying Directv receivers?If you got the Directv receiver from Solid Signal, it's a lease, you don't own it.
Would they want an HR24 DVR back?afaik directv doesn't sell receivers anymore
only way to keep one is if its a model they don't want back (something old)
You may find one on eBay. Find one advertised as owned, get the RID, then contact Directv to verify that it's owned. You will likely have to buy a new access card, usually $20.Is there anyway of buying Directv receivers?
Or a way to keep a deactivated receiver for later use?
I want to own the receivers so I can use them in an RV and deactivate them when I don't need them and reactivate them when I use the RV.thre really is no advantage to owning a receiver.
they all cost the same per month
What's an RID?You may find one on eBay. Find one advertised as owned, get the RID, then contact Directv to verify that it's owned. You will likely have to buy a new access card, usually $20.
Not a bad idea. I'd have to replace the Genie mini clients with HR24 DVRs at home. Too bad the Genie won't work in the RV.just take a home receiver with you.
you cant use it in both places anyway
and if you have an hs17, well you cant have a receiver/dvr on the account with it
Sometimes, sometimes not.Would they want an HR24 DVR back?
Limited time offer
