Receiver not responding to remote | SatelliteGuys.US
  • Thread starter Thread starter NR2D
  • Start date Start date
  • Replies Replies 0
  • Views Views 5K
NR2D
328
33
Laurel Springs NJ
I have a new 211K that all of the sudden stopped responding to the IR remote. I apparently pressed some buttons on the remote and the receiver stopped responding to the remote. I tried another 211K remote and I tried the 1st remote on my other 211k and both work fine.
I tried resetting the receiver by holding the power switch for 10 sec. and unplugged it also. The front panel buttons work with except of the "SYS INFO" button. it does not seem to work, I don't feel a click like I do on the other buttons.
Whats up?:confused:
Edit 1. The "SYS INFO" button on my other 211k does not work either.
Edit 2. Some how the remote address changed. I figured out that to use the front panel "Sys Info" the receiver must be powered off and then you press the button. The receiver is now working OK.
Rich Dunklee
NR2D
61.5 vs. 129 -- very urgent question!!!
Quick question Re: DVR advantage and HD packs
