RCA Remotes | SatelliteGuys.US
RCA Remotes
Plywodstatebum said:
anyone know how to set up the rca remotes to operate my TV's off-on and volume? I couldn't find it in the menu
Looking at your previous posts you don't have a RCA receiver you have a Directv H-10. If you look at the system information the manufacturer is 200 which is Samsung, but that isn't really important Directv is the source of the codes and if the codes listed don't work then you will probably have to use the TV's original remote control. :) :) :)
Thanks I tore my house apart and found my old RCA manuals that came with the remotes it had the codes in it also.
The H-10 will not change channels using my TIVO remote so Tivo is sending me some different cables to try, They said they think DirecTV is doing this so you have to get there DirecTV HDTivo receiver, The Stand alone just dosen't want to work with the H-10 maybe these cables there going to have me work with will tell them how to teach others how to do this.
Big News for Voom on E*, can D* get a similar deal
More Technoloty, Less Ability!
