RCA DTC110 Compatibility | SatelliteGuys.US
Barry Erick
1,020
Dallas
My second HD (loosly used word here) is my old RCA DTC110, with a 4:3 screen.
Remotes (IR Ver 5.3) are not compatible in that pressing the SAT button will change the TV Channel. The older (ver 5.0)
While the RCA has Y Pb Pr inputs and the 622 and 211 have the same type of outputs, the RCA is not compatible with the scan rates output. This was also true of the 811, but a simple X-BOX component->VGA adapter worked. This does not work for the RCA.
I'll probably use this as an excuse to replace this second monitor soon.
replace 500 with 1000?
Closed Captioning
