last night everything i was recording was like on AMC, HBO, SHOWTIME so a OTA wouldn't helpFwiw, I tend to record anything Local on the OTA antenna instead, just incase the weather happens to be bad.
i will later or later this week it's me a hour to hour 1/2 to type out but i don't think it alignment problem.Please post the transponder strengths for all satellites. This will help to determine if you have an alignment problem.
when the the SFSS message come up, it will most likely knock out the SD channels also but not alwaysYou can set up the Guide to show the SD versions of your channels as well as the HD versions (e.g. it will Show HBO twice, HBO and HBOHD). Go to Menu, settings and help, settings, display, preferences.. then on "Guide HD Channels" select on "Hide SD Duplicates", then highlight and select "Show all channels". You'll get a message that it will take a few minutes to take effect, select "OK" then hit the "Exit" button on the remote. Next time you open the guide you should start seeing 2 listings for most HD channels (One wont say HD). If your getting the SFSS message, open the guide and see if theres a non-HD version of the same channel. If there is, change to that one and see if its coming in.
Limited time offer
