Radio Shack/Antennacraft/ Mini-state Amplified TV Antenna with built in rotor | SatelliteGuys.US
  • Thread starter Thread starter radio
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
radio
"On the Air" in MI
3,738
908
West Central Michigan
Call it "Radio Shack" or call it "Antennacraft", (or years ago this was a "Winegard" unit) this is the TV antenna with DIRECTIONAL capability. The elements move INSIDE the plastic dome, no matter in what direction you mount the antenna.
Includes: DOME ANTENNA, ANTENNA MOUNT (SHOWN ATTACHED, REMOVED FOR SHIPMENT) 110 VOLT AMPLIFIER UNIT (OPTIONAL 12 VOLT CORD-NOT INCLUDED,) WHITE COAX CABLE, HAND-HELD REMOTE UNIT, SUPPLY OF 4-CONDUCTOR ROTOR WIRE (ONLY 3 CONDUCTORS NEEDED) AND INSTRUCTIONS. EVERYTHING AS SHOWN!! (Can also sit on a shelf or use in closet/attic with short pipe and flange.) Parts including RV/Boat mounts and info available under the "mini-state" name at solid signal dot com.
Tested for power-on, and movement of rotor. Your reception results may vary, no guarantee on ability to capture specific signals, but it appears to have not seen weather, lightning, or misue! It's clean, and appears to have been used indoors only. Should perform well! Recommend new screws for best connection at amplifier box rotor wire block, available at any local hardware!
Wired remote with lighted rotation indicators as shown. Not for "deep fringe" or "fringe" but likely to work in city and suburban locations better than "set top" type.
$60 plus actual shipping cost of 13 pounds in a 24x24x8 package for your estimating convenience! Continental USA only pls.
Paypal (gift), money order, cleared check all welcome. PM for payment-sending info.
Ipad 16gb Wifi Black
coolsat 8000 HD (But wait there's more!!!)
