R22-200 & RF Remote | SatelliteGuys.US
R22-200 & RF Remote
ismdoug
6
I downloaded a PDF from DBSTalk about my R22-200 and the PDF mentioned the R22-200 supports RF remotes. The remote I received from DirectTV is the RC64 and I believe is only IR. Does anyone have experience with the RF remote and the R22?
Is there any configuration that I need to set up or is there a particular remote I should look for and how well does it work?
THANKS!
Doug
Thanks! Any word on how well these work? Is anyone using the RF remotes with the R22-200?
Doug
Old Commands Lost
What do you do with old receivers?
