I have 034c on my R22-100. And I purchased the HD Access about an hour ago, and I am still NOT seeing HD on my receiver. All the HD options are still grayed out? I tried doing a force update afterward, and that still didn't work.
What should I do? Why isn't this working?
Did you do a red button reset yet?
Yes, I did do a Red Button reset. I few people have told me, that HD will NOT work if add HD access after downloading the Software. is that true?
Josh
Josh
I had the 034C firmware and still no HD channels. I went into setup and the HD channels(Hide HD duplicates) was set . Changed to show HD duplicates. Works for me. But only works for channels below 100.
Also I do believe it must be on HDMI cable.
I quess this is for just HD locals???
jet
Turn the box off on the front. Let the lights all go out. Then unplug the power plug for at least 10 seconds. Plug it back in and "feel the joy" or whatever sat company slogan you want to use.![]()
I made that error thought it was the case(my bad),now they are saying to go into the DirecTV website and reset your services.If that does not work contact DirecTV Tech Support.
P.S. You need to have 034c software on your R22 and HD Access.
I finally got it to work. I had to Unplug my Receiver for 2 min's and then it worked.
Josh
Limited time offer
