R15 Software Releases 0x1194 & 0x1196 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
R15-100 - 0x1194 rollout began 2/29
R15-500 - 0x1194 rollout began 4/2
(R15-300 is currently on 0x1196 - see next post)
0x1194
Improved
Watch Manual Recordings, while recording
Under the hood updates
UI polishing
Stability improvements
Guided setup improvements
Performance improvements
Recording stability improvements
Overall system stability improvements
Interactive stability improvements
Minor UI polishes for recording history
A/V stability improvements
Minor UI polishes for system menu
Caller ID UI behavior improvements
Overall guide stability
Playlist UI minor behavior improvements
Recording / Live viewing interaction improvements
Recording icon behavior for series link
Minor UI polish during system startup
Increased Series Link KEEP Limit to 10
HDD ReFormat behavior
Hard Drive Performance/Stability
Menu to disable scrolling
Active channel DST improvements
New features
Recordings priority over applications
Resume and Start Over Button
Left Arrow Key to mimic Back Key
R15-300 0x1196 - began 3/14
Recording / live viewing interaction improvement.
Minor UI polish for Quick Menu
[Minor UI polish during system startup
Significant Signal Stability Improvement
picture in picture - HD?
