Question: DP34 + Superdish + two 942s | SatelliteGuys.US
HiDefGuy
75
Tidewater, VA
Hello,
I switched over to Dish earlier this year. I have a superdish with a dp34 and an antenna for HD locals. I have one 942 hooked up, and plan on adding another 942 soon. The dp34 has two outputs that aren't being used, can I just hook up two RG-6 and run them to the new 942? Do I just use a splitter for my HD antenna?
Just wondering if its going to be this simple or if I need a new switch...
Are they still only allowing one 942 lease per account?
Thanks for the help.
If memory serves, you will have to buy your 2nd 942 receiver. As far as running new lines, all you have to do is run ports 3 and 4 from the DP34 switch to your 2nd 942 receiver. And yes, it's only a matte of splitting your HD antenna signal
Great. Thats (almost) what I wanted to hear :)
So what's the current story on people who have purchased a 942 and mpeg4 comes out (someday right? No one knows yet?)
Any New Info on SBC Dish?
Installation Question
