GEOSATpro - Question About The New Upcoming Software Update. | SatelliteGuys.US
GEOSATpro Question About The New Upcoming Software Update.
avenger
596
5
Slidell, Louisiana
After the beta testing is sastified and complete, will the new software upgrade contain a new and up to date satellite and TP list?.
There has been some TPs changes made in the past two months or so, and the present satellite list is a liitle bit outdated. Just wishing:)
Thank You.
It would be nice to state which receiver you are asking about..... Kind of hard to answer without that information.
If you mean the MicroHD receiver, you should ask in that forum.
I assume he means the Micro so I moved the thread here
Why worry about an "updated" TP list? A blind scan fixes that ;)
I agree, but a bilnd scan is not doing it or helping me much. As mentioned in my previous MPEG-4........ H-264 video thread.
How much weight does the right VPIDs and APIDs carries on a TPs?
If someone wishes to provide a current Satellite/TP .udf list sorted by KU and C band, we will include. Otherwise the current list is close to current with minor changes.
Unless noted, typically satellite changes are modified and inactive TPs removed.
GEOSATpro What size hard drive for the Micro?
GEOSATpro How do you enter a manual PID in the Micro
