question about recording from online broadcast... | SatelliteGuys.US
elephantgarlic
it says that the tune is playing at 64Kbps...
does that mean i should only record it at 64kbps?
if so, that's sorta low quality.... ?
if i'm only receiving it at 64kbps, then recording it at a higher rate is just going to create larger files with no real benefit, right?
:confused:
You have it correct.
Both XM and SIRIUS stream at kind of low quality rates. Whether the quality is acceptable is a personal call. For me, it mostly depends on what I am recording. If I am capturing talk or news, then I don't use anything higher than 64kbps. If I am getting music files, I bump it up to 128kbps.
You are also correct that it will not help to record at a higher rate than the original signal. Quality in equals the best quality out that you can get.
David K.
Time Trax Customer Service
WOW- Free XM Direct Sat Tuners!
Problem with Recast Online 1.2.6
