Of course it matters.
Your 922 has motor-drive electronics and can swing your dish from bird to bird.
The Pansat does not.
To get the Pansat to move the dish, you would need to install a Vbox or a Gbox
That takes movement commands from the Pansat, and drives the motor.
But then, the 922 couldn't control the dish.
Gotta pick one
The 922 also has control of your polarity servo, to select between vertical and horizontal transponders.
The Pansat does not contol that servo.
It could drive a voltage-controlled LNBF, but it sounds like it's far too late to make a change now.
Not saying a change would be a good idea, either.
It's apples and oranges - whichever suits you, is the right one.
So, anyway, to get the Pansat onto a desired bird, you'll need to swing the dish with the 922.
If you want to record a show, just be sure you're on the proper satellite before the recording begins.
Possible Solution: Get another BUD. --
