question about looping receivers | SatelliteGuys.US
LNB--->"IN" Mercury "Loop Out"---->"IN" NFusion
This way the Mercury would be the Master - Controlling Dish and Switches
If you Power Down / Stand By the Merc, then the NFusion will be able to control Dish and Switches
It does not matter which is the "Master" receiver, I'd go with which ever you use the most.
Controlling dish and switches also means polarity.
When both are on, you can only see TPs of the same polarity on the slave box as what the master is looking at. Can't see V polarity on master box and see H on slave box simultaneously and vice versa.
Dish in Hinkley , Ohio
Where is CBS now?
