ques for Quapoharry | SatelliteGuys.US
ques for Quapoharry
outbackjack
276
7
maine
Quapoharry, i wanted to try the setup you used with the c lnb offset. i tried the dmx mod and can only get cband but no pic despite 63 qual. if i bought the sprinkler bracket to put next to the ku lnb what degree bend does it need to be on the same focal point? and how far from the ku does it need to be? thanks for any info.
On my Coolsat 6000P SQ of 63 produces no usable signal. Exception is NHK and RFDTV. 66% SQ is minimum for stable pic. in good weather.
so my ques now would be what would be the best c band and bracket to go next to the ku to experiment with? and who sells it. i would like it to be a lighter lnb because the heavy dmx741 really messed up my settings despite everything being tight. thanks guys:)
SES-1 Launch Successful
Absent
