Putting programs on DVD | SatelliteGuys.US
CEV
SatelliteGuys Guru
142
15
Has anyone here put there D*Tivo programs onto DVD using there computer? I would like to do this and need to know if there will be any issues. I will be hooking up the D*Tivo box to a Dazzle150 that is connected to my computer. Will I have any issues playing these DVD's on other TVs?
Thanks,
CEV
I have used my SD Tivo with my pinnacle breakout box. It came with the Studio AV_DV Deluxe. It is very similar to the dazzle product. You may not be able to capture at full resolution but the SD Tivo is already compressed so it should look OK. Capturing the video via an analog solution and changing it back to digital is not the best solution but it does give you a way to back up your shows.
Thanks, I'm going to give it a try and see how it turns out.
damaged said:
No problem, let us know how it worked out. Good luck.
Works just like I wanted it to!! No problems at all!!
Thanks,
CEV
Hd Dvr 10-250
