Pursuit Channel on DSR410? | SatelliteGuys.US
49studebaker
71
I have a DSR 410 and I would like to receive the Pursuit Channel. In the DSR410's System Settings Menu I pressed: 6, 7, 7, 8 to gain access to the hidden System Configuration Menu, I then selected Manual Tune Frequency. Next, I entered the following:
Polarity: Left
Frequency: 1030.000
Symbol Rate: 19.51
Coding Rate: 3/4
The light on my DSR410 turned green and the signal strength and signal quality show 99%.
My question is how do I view the channel? Would I need to do a "Authorization Reset" or a "Reset to Factory Defaults"? If I do either of those resets would that prevent my DSR410 from being able to subscribe to Skyvision if I choose to do so in the future?
I think the 410 willonly work with W5 and the Shaw maps. I dont think it can do generics like the 4DTV can
Even some cable co's must use smaller C-Band dishes
Newbie to FTA,Need help
