PTAT- Autohop Delay ? | SatelliteGuys.US
ggw2000
693
110
Out here somewhere
With new shows starting for the most part next Monday, I can't remember what the Autohop delay is for the 4 different networks? I believe CBS is still 7 days? Not sure about the rest...
Anyone know exactly what the current delay is for: CBS, NBC, ABC, & FOX ?
Thanks, Gerry
Appreciate the answer to my question- thanks!
Another question if anyone knows the answer. I installed my HWS/SJ combo at the end of January and everything seem to work fine with PTAT for a couple months. Then I started randomly having shows that I had timers set for ending up cutoff by 5-10 minutes before their end with PTAT.
This summer I asked the question about this here and someone said it was a known problem. He said to "go into the daily schedule and click on the shows that you have timers set for and hit restore". He said this would produce a third copy of that show and Autohop would still work for those shows and would fix the problem with shows coming up short..
Does anyone have any experience with this solution to the problem?
Thanks, Gerry
FYI NBC O&O is now 7 days as well.
All CBS-8 days
All Fox-7 days
ABC O&O-3 days
All other ABC's-none
NBC O&O-7 days
All other NBC's-none
Most likely peeps never used this feature much. I used the feature about twice in the past two years. Never seen anything on networks worth recording.
Sent from my iPad using SatelliteGuys mobile app
Hopper3 / Joey LAN Wiring Question
Hopper 3Woes
