Properly Hooked Up? | SatelliteGuys.US
Properly Hooked Up?
vbsafire
6
I am just curious if my RPTV is hooked up correctly. I have an 811 HD tuner hooked up to a Pioneer PRO510. It is hooked up via component cables and not a DVI cable.
I have adjusted the picture considerably and it has helped. Just curious if it can be better?
Also, is there any word as to when Dish will add more HD channels?
With RPTV, there is little difference between DVI and Component hookups. I have tried both and currently use DVI but I would not have a problem using compnent. Dark video is an issue that E* is supposed to come up with a fix soon. (w/in two weeks as told to me by a Tech support Rep)
Fox Widescreen with Dish 811
has anyone switched from cable to dish and been happy they did?
