Programming d/l never finishes | SatelliteGuys.US
Phils
115
Paradise, CA
The last few weeks AFIK, whenever the program guide is being downloaded to my 622, the progress bar ALMOST gets to the end and then stops. I've waited over 5 minutes for it to finish, and that's after at least 5 minutes to d/l up to that point (which is normal). Selecting 'cancel' gets me back to normal and it's not a devastating problem but does anybody know why? There's still room on the h/d to record shows but I expect that would have nothing to do with it.
Phil
There does seem to be a problem, hope it's not with my 622.
I got to that last 5% on a forced d/l again and just let it sit there. After about 10 minutes the screen flashed to 'acquiring sat' for about half of a second then back to normal programs. It never did finish that last little bit tho, according to the progress bar.
Phil
If you cancel dish they want LNBF
Advice for HD 2nd receiver install....
