Program infomation... | SatelliteGuys.US
rmosso1
16
Macon, GA
I have five Direct TV receivers. Only the receiver that is the DVR lists programs as to their first air date. Is there any way to get this info from the other receivers? By looking at the first airdate you know if the program is a rerun or NEW.
Thanks for answer.
Thanks for answer.
This is a fairly new thing that D* has added, I too really like it.
It was added in the software for the particular recvr.
No word as to if they will add the feature for all of them.
I would like to see it added to others, but don't know if it will.
Thanks for answer.
I don't think there's a way to see this on the other receivers.
Problems sending back bad HD receiver!
no signal in motor home on directv set up
