Prodelin feedhorn | SatelliteGuys.US
Prodelin feedhorn
Don't mean to burst your bubble, but that looks like a Scaler Ring? Where do you mount the C-Band LNB at? Those holes don't match any C-Band LNB I've ever seen? Good Luck....!
I think there is a piece missing...?? But, what do I know...?????
If you look at this C-Band Feedhorn:
C Band Feed for Offset Dishes
It has the extra piece I'm talking about. You can mount an LNB to this one. I don't see how to mount it to the one you posted? This is a Channel Master Feedhorn, but I would bet the extra piece would bolt right up to the Prodelin Scaler Ring..??
I plan on using it as a conical scalar ring with a C-band feedhorn I already have. Its worth a shot.
That looks like the front part of the transmitter assembly that came off my Prodelin dish. I believe unique to that feedhorn. It has 6 bolts that secure it.
Looks similar Corrado. This is the closest thing I have been able to find to a conical scalar on ebay at a decent price, so I bought it. It may take a little modding to work, but hey thats half the fun of this hobby ;)
Help me get a sat signal... any sat signal
1.2m dishes available?
