problems with my openbox s10 | SatelliteGuys.US
Does anyone know why I getting 21 v from receiver to my lnb?
Not knowing how your measuring it, it's possible since that's a switching power supply if your measuring it without a load then that maybe the correct voltage. You need to hook up the LNB and then measure it at the power supply.
Looking at the inside of the S10 you may have also just smoked a a component on the small board that the connector goes in to.
Is it still under the factory or dealer warranty?
Polor Rotor control?
