Problems with cheap meter and Dish hopper | SatelliteGuys.US
chapin4life
91
Hi guys I just moved places, I own my hopper and dish I'm trying to align my 1000.2 dish with a cheap $15 meter
the problem I'm facing is when I connect the meter to the hopper the needle goes up and down by itself without moving the dish or meter knob, do I need a meter that has 22KHz?
I tried a new set of rg6 cables and also a buddy borrowed a another cheap meter, same thing happens once you connect the meter to the hopper (REC) the needle moves up and down by itself every 10 seconds without moving the dish.
I am not an expert, but I think you can connect the meter to the dish 119 LNB port and am it hopefully at the 119 sat. The you may need to fine tune the scew to bring in 110 and 129, after removing the meter and connecting the Hopper.
I have a Hopper in my RV and whenever I use my portable 1000.4 dish -- which is frequently -- I use an Acutrac III+ signal strength meter:
The meter costs over $200, but makes it a breeze to acquire sats because it shows the signal strength of 3 sats in real time.
However, in your case, unless you're constantly on the move, why don't you just have a DISH installer do it?
Accessing EHD
Sling Issue
