Problems with channels 202 & 132 | SatelliteGuys.US
bnewt
1,488
551
Shepherdsville, Ky
Is anyone else having problems with these 2 channels - hd version? Most of the time if I key in these channels or select them from the guide, I get a lost signal error. They will come in if I use the channel up/down button. This is something that has recently started on my 722. I have another 722 in another room that does not seem to have this problem.
Zach,
I have the same issue with 202 HD, HLN. Seems to only happen on TV 2. I have rebooted but not done a check switch recently. Will try that and see if there is improvement.
Ross
Sent from my DROIDX using SatelliteGuys
Zach,
Ross
Turn off Dual Mode, Hit "swap" on remote, then go back to Dual Mode :)
ZachS@DISH Network said:
R0ss,
Let me know what happens.
Did CS. No change. Still lose HLN randomly. It does occur on tv 1 as well as tv 2. Originally I made the asumption that it was a tv 2 issue but that may have been based on the fact the HLN was being watched on tv2 more than tv1
Ross
Moved
optical out audio
