Problems at 110 | SatelliteGuys.US
Problems at 110
3:41 am (Central Time) on July 25th, and my 110 reception has been poo
for the last couple hours. My satellite strength is bouncing between 0 and 48.
I believe it was sitting steadily at about 105 signal strength before these
problems this night and last. I'm relieved to hear the problem is at the up-signal end,
and it's not a new random bug of the 811. God I hate my 811 so bad.
I've noticed that 110 is not running as hot as it normally did. Usually on Tp 11 I would average around 103-104 constantly. Now it is running around 100 or 99. 119 is not affected...it still is coming in at 119-120.
I notice from time to time that some transponders will lose strength as others will gain strength. Maybe this is due to the fact that these satellites do drift a little causing the center focus the dish is set at on the satellite is seeing a different part of the satellite than it does other times.
How to upgrade receivers? Where to start?
Any 921 timer problems with Detroit OTA's?
