Problem with (non-existant??) switch | SatelliteGuys.US
onkyo
6
i can home from work to watch some tv and found that I couldn't receive any channels. The error on screen is:
A problem has been detected with your multi-dish switch.
When I run through the the help available, I eventually get to the switch check screen. It doesn't find any of the satellites and I get the following message:
You have an error with your multidish table. Please run a checkswitch.
is there anyone out there that can help me with this issue.
Please and thanks,
Onkyo
could be any number of things... lnb died, dish out of line, bad connection, bad wire, ect.
You have to do some troubleshooting.
Here is a couple questions to try to help find the problem.
What model receiver is it?
Which model dish? Dish 500? 300? 1000? ect
Any idea what lnb you have?
Do you have any other recievers connected to the same dish?
Do you have any other receivers connected to the same dish?
i have a dvr 501 and receiver 311 and the model is dish 500
everything works fine in the bedroom even if i switch boxes they still work i get all the channels in the bedroom but in the living room i dont .
i did check between the box and the wall took it all apart and made sure everything was tight. as for the dish part it will have to wait till tomorrow thanks for the replies
Is anybody having a problem with dish today?? I lost the picture on my main tv three times in the last couple of hours. I still have sound and there is a pic on the 2nd tv in the back room. I tried moving the cables and turning the receiver off,but no luck and then it just popped on each time. anybody got any ideas
Getting HD via cable input
ghosts
