Problem with 95W G3C | SatelliteGuys.US
706Tom
69
North Georgia
I live in north Georgia and can not receive the two CBS stations on 4167 @6614 SR. I can receive all kinds of horse racing, but I get no signal level at this transponder on my CS5000 or my Traxis 3500. I've moved my 9' BUD all over the place with no effect. Any suggestions? Anyone in N. Georgia having any problems?
They're working fine here in MN on the 6 footer. Just had them up about an hour ago.
All the horse racing channels you are getting are you sure they're vertical transponders? I know those channels (racing) are on both polarities
Thanks Iceberg, That would be the common factor between the two receivers. I use an old analog receiver to move the dish and to change between Hor and Ver. If the LNB isn't going to vertical mode that would answer a lot of questions. I need to look into the feed and see the unit change polarity.
See if you can lock My Family TV. That is also on vertical
3744
V
2206
the signal is SCREAMING at a 99 here on a 6 footer...stays at 99 even if I'm off by a degree ;)
New n00b here
shopping channel on AMC6ku
