Problem with 129 going thru Dish Pro Plus | SatelliteGuys.US
dewey brunner
16
My set up. 622 and 942. 1000 dish with Dish Pro Plus Lnb. No 44 switches. Just two lines, one to 942 and another to 622.
Dish positioned with meter correctly. Disconned line fron 129 lnb(bypass Dish Pro Plus lnb) and hook directly to 622. 129 signal on 30, 90-95. Hook back up thru Dish Pro Plus lnb. No signal on transponder at all. Re-try time and again with same results. tried disconnedted to 942. Made no difference.. I.E. when hooked up straight to 622 got good strong signal.
Tech support stated it appeared I had a bad LNB. I do know it got real hot.
Any one else tried this or had problems with Dish Pro Plus lnb? I cannot see where I have overlooked anything. Suggestions or comments? Thanks Dewey in Tampa
Advice needed for my tailgate setup
Dish or ComCast?
